OffGridMike
I am having a heck of a time getting my settings where I want them with my Charge Controller and Inverter. Looking for suggestions.
My system:
Xantrex XW 6068 hybrid 120/240 60 inverter/charger
Conext MPPT 60 150 solar charge controller
4x 48V100ah EG4 LiFePower4 batteries
connected with the EG4 communications hub to an Insight Home communications hub
The problem I am having now is that I keep getting DC overvoltage warnings and faults. My batteries run down to about 90% overnight. In the morning, the sun comes up and recharges. Once they get to 100%, the charge controller seems to put out too high voltage to the inverter and it faults.
I keep hoping the settings will auto-populate correctly with the communications hub, but no dice. When I try to manually change the settings to match the diagrams in the EG4 battery setup guide, they revert back to the default.
I will start with a couple questions I assume are easy.
1) Why can't I update the battery type and charge cycle? When I change them to Li-Ion and External BMS, they go RED after I hit apply. They revert back to Custom & 3 Stage.
![1719363398164.png 1719363398164.png](https://diysolarforum.com/data/attachments/224/224652-16f154a24378b6f815875a16566049af.jpg)
2) What setting can I adjust to limit the voltage on the MPPT Charge Controller? I think I need to set a limit of ~57.1 but it keeps sending out more than 58. These are settings for my charge controller.
![1719363674113.png 1719363674113.png](https://diysolarforum.com/data/attachments/224/224655-ad588c70509dfff91e64259636ed88ea.jpg)
![1719363807681.png 1719363807681.png](https://diysolarforum.com/data/attachments/224/224657-3b9092c4d2911d9edfbf32f9736dbbbf.jpg)
![1719363756463.png 1719363756463.png](https://diysolarforum.com/data/attachments/224/224656-625453570aeb79b30d0d07dd9ddaab74.jpg)
My system:
