SolarScott
- Sep 27, 2022
- 469
Today I took some time to try and equalize all four of my lifepower4 batteries. One or two always seems to show a little less of a charge according to the lights. Used solar from the inverters to charge one at a time until they showed full at the light bar. Close to sundown, two were a still a little behind, so I used my chargerverter to top them off. When charging from the inverters, I use the "USE" setting and 56.2 volts and 54 float. I have never seen the batteries show more than 54.1 or 54.2 indicated by the inverters. When using the chargerverter set at 56.2, the inverters showed 55 volts when all four lights were lit up on the batteries. Pleas explain to an ignorant man what this means.
