grizzzman
Photon Vampire
- Sep 21, 2019
- 2,860
I run mine at 2.8 with no issues.I found the answer in another thread so posting the link here as well.
Jason at Chargery said it will work for a 4S battery down to 11V. So I guess if LVC is set to 2.8V or higher it could work but there would not be much margin. Probably safer at 2.9V.![]()
Chargery BMS now with Low Temp Cutoff
Are you sure about that? I have mine connected only through the balance cables and it turns on. I haven't checked if it has enough juice to power the relais though I think it means that it will not be enough to power relays fully not the BMS in general. I was looking at a possible DIY battery...diysolarforum.com
