Hey guys, I recently purchased 16 used cells im building in a 13kw battery, anyway, I bought a bench power supply so I can top balance the cells. I understand you first use constant current then switch to constant voltage to finish charging.i set my voltage to 4.1v on the supply, connected it to a cell and it started charging at constant current at 4.3v 10.3amps. is it ok for the charge voltage to be higher than the cell can take? Or is the maximum cell voltage the maximum charged state? I don't want to f these batteries up. Also, the reason I'm charging single cells is because none of them are at the same SOC, and when I went to connect them in series I was getting sparks and a warm wire (I knew something was amiss right away). Is there a better/faster way to get all the cells at a similar SOC? Thanks
