I have a Seplos BMS 100A, new version 10E
This bms considers 100% when the single cell overvoltage protection or the total voltage overvoltage protection is triggered
I have these set to 3.5V and 56V respectively
Today I started charging when I was at 80% at 50A; after 1 hour the voltage was 55V and rapidly increasing, it would have reached 56V in a matter of minutes; the SoC had been stuck at 98.2% for a while
So I dropped the current 9A (the bms has a set voltage called ‘overvoltage alarm’ that does the same when a certain voltage is hit, but I did this through the inverter)
As soon as I dropped the current, the voltage dropped from 55V to 53.8V and after 2 hours it was still at 54.5V, which is lower than what it was 2 hours before when the current was 50A
So I can hit 100% (overvoltage protection) by charging at 50A, but charging at lower amperage (9A) seems to never get me there
It would seem beneficial to charge at a lower rate when close to 100%, but it just seems to never reach 100% because the voltage doesn’t increase
