My Rheem 40 gallon water heater is around 6 years old and works great.
My dilemma is that we take showers when the electricity rates are the highest. Our 15kwh battery has enough capacity to run the hot water heater but we are limited on how many amps we can feed into our main panel.
We have a Solark 12 K that feeds into a sub panel for our garage and heat pump and then feeds into our main breaker.
I looked at hybrid water heaters but the price doesn’t seem to justify the cost and the location wouldn’t work since it would cool the upstairs in the winter.
I looked at lower wattage water heaters but those still run about $500 or so.
Not being one to replace units that work I did some research and found I could replace the 4500 watt heating elements with 3500 watt elements. I also ordered a new anode rod.
This 1000 watt reduction should keep us from drawing from the grid when rates are the highest.
Around $75 for all the parts.
We’ll let you know how this works out.
