This is the specs i have. Should I ask something to find out why the cost is so cheap. This is what the email said: Thanks a lot for your inquiry.
This is Yilia from Mica Power. We are a professional battery manufactuer with about 15 years' experience in rechargeable battery.
The unit price is $1290 FOB Shenzhen. Sample is available.
The dimension is 460(L)*400(W)*250(H).
General Information | |
Battery Type | LiFePO4(Lithium Iron Phosphate) |
Nominal Voltage | 12.8V |
Nominal Capacity | 600Ah25ºC,C10 |
Nominal Energy | 3468Wh25ºC,C10 |
Operation Voltage | 10~14.6V |
Operation Temperature | Charge: 0°C - 45°C | Discharge: -20°C - 60°C |
Cycle Life 100%DOD | >3000 cycles (7680Wh25ºC,C10) |
Cycle Life 80%DOD | >4000 cycles (6144Wh25ºC,C10) |
Cycle Life 50%DOD | >6000 cycles (3840Wh25ºC,C10) |
Weight | ~63.5 kg |
Environment Protection | IP56 |
BMS/Charge/Discharge | |
Charge Voltage Max | 14.6V |
Discharge Cut-off Voltage | 10V |
Charge Current Max | 1C |
Discharge Current Max | 1C-2C |
Self-discharge Rate | <2% per month |
Self-discharge Rate | Over-charge protection Over-discharge protection Over current protection Cell balancing function Over temperature protection |
