Here are few pictures of the cheapest galvanised steel/aluminum ground mount I found to buy (for 24 2.3x1.14m panels mounted vertically in two rows)
What do you think? Especially about the "unusual" way to make the posts longer.
It consists of:
- 25 2.3m (90in or 7.5ft) fencing posts (they are 2mm/14 gauge galvanised steel).
- 24 aluminium mounting profiles.
- A2 stainless bolts/nuts
- aluminium holders, profile joining brackets
I had to cut the posts to length and drill the bolt holes.
Currently this is just the supports sitting in 80cm (31in) deep holes that will be filled with concrete. Aluminium channels will be mounted horizontally on this.
I plan to use long steel channels clamped on top to straighten and align it all. Then to pour concrete and once it sets attach aluminum channels. I'm also going to use a zink spray paint to improve the corrosion resistance where it was cut/drilled.
![20240527_194713.jpg 20240527_194713.jpg](https://diysolarforum.com/data/attachments/218/218174-533d278dcad3df90268cb6f2e08436a3.jpg)
![20240527_194709.jpg 20240527_194709.jpg](https://diysolarforum.com/data/attachments/218/218175-32965f29a35e24990b98f4f32e2fa35f.jpg)
![20240527_194705.jpg 20240527_194705.jpg](https://diysolarforum.com/data/attachments/218/218176-34ad9e063635f02411ea6e1755cdee78.jpg)
![20240527_194655.jpg 20240527_194655.jpg](https://diysolarforum.com/data/attachments/218/218177-8b300453f6fea733461c513f44ef6e94.jpg)
(behind is my old array, there will be a little shading, but I'll likely be moving it at some point).
I paid a very low price for it(a third of what a normal ground mount costs) and the seller honestly says he never did any wind load calculations, but "they've been selling it for years" with no problems. In my area things are usually designed for a max wind load of 100km/h (60mph).
I decided to give it a try as I can always make it stronger later if necessary.
It consists of:
