Famous_addit
- Jul 7, 2022
- 14
Hello,
I have two LiFe4po 2.5 kWh 12v batteries and the weather is starting to get pretty cold where I am.
The batteries do not have an internal heater and I will need to use them throughout winter. I live off grid is an old unheated stone house in the Alps so the room they are kept in is only marginally warmer than the outside temperature.
At present it is only dropping below freezing at night, when they are not charging (currently being charged by 800w of solar), however I expect it to drop below freezing during the day time some time in the next couple of weeks.
I have read that you should not charge LiFe4po batteries is their temperature is below zero centigrade. So, my question is: how can I continue to use these batteries throughout winter?
I have seen these small heating pads that people use to make mini green houses or to heat car seats. Could I just sit my batteries on one of these all winter? Any other ideas or if there is a proven solution (I can't be the first person to encounter this), I welcome your insight.
TIA
Z
TIA
Z
