Bluedog225
Texas
- Nov 18, 2019
- 3,268
Good afternoon,
Tl-dr- I’ve been trying to put together two strings of three panels in parallel. It’s not going well. This voltage is as expected around 100 V. (Maybe that’s low but it’s consistent. ).
But the amperage drops when I combine strings. The amperage does not drop when I run a single string. Total production on a single string is a 750 watt range. But around 500 with the combined strings.
These are all from the same batch of used panels that looked fairly new. But maybe they’re jacked. I can pull some others out of storage and see if they work differently.
The individual panels seem to test well. And the strings test at 100 volts consistently.
The amps on the individual panels are in the 7 to 8 range. When I combine the strings every time it drops the amps to 4 to 5 amps
I’ve got three strings of three seeing if I can isolate something wrong. But it’s consistent. Panels the produce 7 A on the tester produced 4 to 5 A when put in series and hooked up to the charge controller.
It’s quite hot out here if that makes a difference. Does anything obvious jump out at you guys? I have tested the strings individually and in different combinations. Same results.
Not sure what to do at this point. I don’t have fuses or combiner box so I’m limited to two parallel strings. At least for this trip. I’ve got two MPPT‘s and was going to run 32P on each MPPT.
Well, I guess I still am. Sorry if I’m rambling. It’s pretty hot.
Any ideas?
Any ideas?
