So that was probably it.
Assuming no other "variables", like system running with AC or battery, which were turned off the next time you tried.
One guy got a shock from the PV connection of an inverter, even though PV hadn't been connected. It appears voltage leaked through and charged up the capacitors.
Yours at 3V is low enough to not worry about. But always check before touching, and if necessary disconnect other sources.
And check voltage to ground. Some systems have PV isolated, could be at a potential relative to ground. Some of mine drive the PV terminals during power-up to confirm they are isolated.
