theHouserHouse
- Sep 5, 2020
- 27
We're serious newbies working on putting solar on our travel trailer and need some guidance. Right now we are trying to connect our eight 100w solar panels together.
They are set up 2 together in series
Each series has a 15amp in-line fuse on the positive wire
Then the 4 sets are going to be connected together in parallel at busbars in a waterproof box up on the roof of the trailer.
That's 4 positive and 4 negative 10g wires coming in to the box
One positive and 1 negative 6g wire will go from the box down into the camper. On the positive wire there will be a 30amp fuse. The wires then go on to the solar charge controller
We're struggling with picking out the correct busbars and corresponding ring terminal connectors.
We have a 5.5x7.5" waterproof box that has 10 port holes. It looks like it will hold two 4" busbars and the wires nicely, I think? We have to account for the gland entries (or nipples) that need to be added on to the box as well.
I forgot to mention the volts and amps of our array...
Each set in series 41.2 volts and 4.85 amps
Four sets in parallel 41.2 volts and 19.4 amps
Any thoughts on the busbars and terminal connectors we should be buying?
