When designing a DIY LiFePO4 battery, is there an order or logical arrangement of the components, in terms of which device "cuts off" first?
Do you want the BMS to be rated lower than the inverter, so it always shuts down before the inverter reaches its highest possible setting? Do want the BMS to be rated higher than the potential output of the inverter and count on the inverter to cut off voltage?
I'm building a pack with 230AH EVE cells, in a 4S-12v arrangement. I am using a Renogy 1,000w inverter. This is for outdoor and off-grid recreation where I want a fair amount storage capacity, but won't have any heavy loads. The BMS I'm looking at is rated for 120 amps, so around 1,500 watts. The inverter can't sustain that, but I would like to be able to start the compressor on a small chest freezer, if needed.
Thanks in advance for any feedback.
