dobermankby
- Jan 23, 2022
- 2
Hello, I'm trying decide on a battery system for my first camper van that I'm currently working on converting.
I will use this van mostly for weekend/extended weekend trips, and maybe a couple occasional 7-10 day long road trips per year.
I was initially thinking of Bluetti AC200P, but the issues (especially idle drainage even when the inverter is OFF, or inaccurate battery level display issues) turned me off a bit. Also I don't need AC - certainly not 6 (six) AC outputs - so that felt a bit like overkill. So I figured I can get a separate battery for less $ and have better reliability.
I'm thinking of starting simple (no inverter, no solar, only charging via AC outlet for now) and add those if I need in the future.
Here's what I'm currently thinking:
This battery has a BMS, temperature and discharging protections, and a Bluetooth for monitoring the battery state. I especially like the bluetooth monitoring which eliminates the need for a separate battery monitor. Please let me know if this is a bad assumption.
Next question: Do I need any other components to begin with other than the two listed above? For example, do I need a fan & temp sensor to keep the battery cool?
What about if I add solar + MPPT? Do I need a fan to cool down the MPPT?
I'm mainly confused by the existence of fans in all in one systems like MPPSolar. Do those fans exist mainly to keep the inverter cool? Or the MPPT? When you use a battery + MPPSolar do you still add a fan to the battery as well?
I appreciate all the input in advance. Thanks.
- Renogy 12V 200Ah Lithium Iron Phosphate Battery w/ Bluetooth ($1099)
- Renogy AC-DC charger for Lifepo4 batteries (20A) ($140)
