Aitch
- Sep 20, 2019
- 75
I have a goal zero panel and a yeti 1400 and I have an mc4 to goal zero 8mm adapter so I can connect my Renogy panel to the yeti.
What if I want to connect my goal zero panel to anything other than the yeti?
The panel has a male 8mm plug the only adapters available have male 8mm plugs too as they can only be attached to a yeti which has two 8mm female sockets.
Goal zero don’t make female to female cables or adapters, so if you buy a goal zero panel you can’t connect it to anything else.
Kinda makes buying goal zero panels a bit pointless (not just because of the stupidly expensive asking price!).
The ‘generators’ are universal (with adapters) but the panels are not!
Any way around this?
