frankz66
Hello everyone, I have attached the image, where on the one that refers to the 4210AN is currently the one I use. I would like to replace the 4210AN with the 8415AN model. I see that the pattern is different, but I assume that if I copy the same cable pattern, it should work. I was asking if anyone in simple words can explain to me the configuration of the model 8415AN, which to my limited knowledge, I seem to understand that this model is able according to the voltages to be able to disconnect from the solar panels according to the voltages and to be able to connect a generator with ats management equipped with a 220v charge controller, or am I wrong? Also this 8415AN controller can I monitor it with the software I currently use for the 4210AN epv solar station ? Thank you .
