offgrider
- Jul 20, 2020
- 65
I have an operational grid-tied solark12k maxed out on panels with 32 of the 280ah lifepos from lightning-power nearly ready to be connected. Planning on a 16s2p setup to export as little power as possible.
The Orion BMS people are working with me to get this Jr2 unit working with my Solark12k (Victron CAN protocol) and they are being very helpful with all my questions. But I have 1 final concern that I'd like to run through the group here - Now, normally the CAN bus will drive all battery operations, and we know the contactor is the last resort protection here; this particular BMS has 2 separate output signals for last resort protection: "charge enable" & "discharge enable" where I guess I have to pick 1 to use.
But it seems I cannot have both types of protection? Is this normal for all other BMSs?
And lets say I pick #1 there since I hold my entire house as much more valuable than a forever useless battery bank.. Under regular operations would I ever be in a position where the sun is shining strong, the panels are providing all the power the house needs and have also just topped off the batteries and the BMS thinks to itself: "hey you know what, these batteries are full, I need to remove the signal from the charge enable pin" and if it does that, then my contactor de-energizes and the batteries are disconnected from the solark and I cannot even draw power from the batteris even though they are currently full? Or does it not work that way and the BMS only de-energizes the "charge enable" if it believe the solark has ignored CAN commands to stop sending current to the battery?
- Where if I pick the "charge enable" signal to drive my contactor, then whenever the BMS thinks the battery may be too full it will disengage that contactor, disconnecting my battery's terminal from the Solark. This can prevent my house from burning down by overcharging the batteries.
- And where if I pick the "discharge enable" signal to drive my contactor, then whenever the BMS thinks the battery may be too low it will disengage that contactor, disconnecting my battery's terminal from the Solark. This can prevent my batteries from ruining themselves by going too far below 2.5v.
