sailingharry
I'm trying to settle on a BMS. My power needs are fairly high, potentially over 300A both charge and discharge. Also, since it is going on a boat, I have to be aware of ABYC (building code for boats) requirements. Also, since it's on a boat, I have space and power constraints. So, that said, I need:
* Contactor based (I'm going to use a single contactor)
* Multiple I/O ports -- one to open main contactor, one to set a HV alarm, one to turn off charging sources, one to turn off discharging sources and alarm, one to open main contactor. Depending on configuration, this can be done with 4 ports.
* Balancing. I'm looking at 600-900Ah, can this be done with passive? I don't know how much balancing is actually done on an active battery, or does it tend to stay close.
* Display. I have and will keep an old LINK 2000 battery monitor, which will show me SOC, pack volts, and amps. This may be all I need on a daily basis, in which case a phone-based solution for details is fine. Some BMS use a web browser to get to the controls, which seems very complex for quick checks.
Assessing the market is not easy! But I've found
* 123Smart, Chargery, and JK don't seem to have more controls than one or two main contactors. No alarms, no charge/discharge controls. So all fail.
* Nuvation at $764 is nice, but way higher cost than anyone else. Also, no display at all.
* Orion 2JR at $670 is also likely to meet the requirements, but has no display and no wifi ($$ option).
* Batrium at $596 is a very strong contender. I can't really work out all the details on making it work, but it looks like it has everything. It can't use my existing shunt, which is unfortunate. It has no display at all, but has a wifi connection for using a phone browser.
* REC ABMS at $572 (with optional wifi module) is a very strong contender as well. I've worked through most of the details and I think it can do it all. I think it is the only Active ballancer, at 2A. I'm very confused at the two firmware options -- CAN and non-CAN. Even though there are 4 ports, I don't think they can be configured to meet my plan. But I think it is "close enough." There is no display. Cell control is through phone browser. The physical device is very robust.
* Electrodacus at $162 (am I reading that right?!!) It has the same control limitations as the REC (ie, I can't get a HV alarm), but still "close enough." Passive balancing (is that enough?) It actually has a display. It requires a high side shunt, so I'll end up with 2 shunts on the system (my LINK on the low side).
So, questions:
* The bang-for-buck for Electrodacus seems hard to resist.
* The lack of display for everyone else is a problem. Especially since there are no "apps." The Victron App, for instance, is "open and read data." These all seem to be "connect to wifi, open browser, navigate to URL, read data."
* Am I correct that my LINK giving me SOC, volts, and amps gives me 99% of all I need on a daily basis, and I don't actually need to look at the BMS controls?
* Is the Electrodacus passive balancing enough?
* Did I miss a worthy contender in my list?
* Am I being foolishly attracted to the low price of the Electrodacus, and the extra $400 for a REc or Batriumis money well spent?
Thanks for input!
So, questions:
Thanks for input!
