teckersley
- Dec 30, 2022
- 33
Hi all. Couple of questions here. I have been using the jkBMS in high speed golf cart applications for a while now and the b2a24s20p has been performing very well so I cannot complain.
Recently, I have been asked to make a couple of battery packs that are a bit out of the ordinary and I would like some input from the group:
1) 24S 300A - yes someone is running a high speed motor and believe it or not 37" tires on a golf cart. I am not sure what is going to happen with the JK but i wanted to see if you guys can recommend a reliable BMS that can support 24s and 300A continuous. Wide open current on a regular cart with 23" tires and the same motor/controller is 170-180A.
2) 35s 250-300A - This will be going in a different type of low speed vehicle. It's quite a bit heavier than a golf cart and yes, 115V or so.
Any recommendations on a tested and reliable BMS for either application would be greatly appreciated. I would like to stick with JK and maybe even JBD but neither seem to have the specs I need.
Thanks
Thanks
