I am a bit confused about how to wire my setup. I have a REC ABMS Victron compatible, and a Cerbo GX, a Victron MPPT and a Victron DCDC charger. I want to have seperate contactors for charge and discharge. The non Victron REC shows this wiring, having charge and discharge contactor seperate.
The Victron version's manual however lists a "main" contactor, which has Victron MPPT and Inverter on the one side, which is charge and discharge. Then the second contactor in that diagram is labelled "contactor 2" and goes to "non Victron components". So how can I wire this with seperate contactors? Do I need to change the default parameters to have the contactor 2 act as a discharge contactor?
