Hi all,
Has anyone managed to connect their REC ABMS to Raspberry Pi for monitoring and data integration? I saw Andy on off-grid garage has done this with a Seplos bms and since REC is CAN enabled, I figured this should be possible - however the REC bms isn't listed in Louis Van Der Valk's page in GitHub.
If I can't use the Raspberry Pi, what is my best work around? I want to avoid paying out for the Cerbo is I can avoid it. I already have the Raspberry hooked up with Venus OS installed.
Many thanks,
Helen
Many thanks,
Helen
