Problems Setting up a Cerbo GX on a Raspberry Pi with MacBook Pro laptop
featherlite
Southern Indiana
In a separate thread captioned “How Do I pair my iPhone with my GX Raspberry Pi Running Victron Venus?”, I asked for help about my iPhone.
Now, I am having a completely separate set of problems setting up that same Cerbo GX on a Raspberry Pi using my MacBook pro laptop.
The problem now is that, on my laptop, after connecting to the Victron VRM web page, I cannot see any data generated by my Victron Smart Shunt. The Smart Shunt is the only device I currently have plugged into the Pi, using an OEM “Victron VE Direct to USB Interface” cable.
Using the Victron Connect app on my laptop, I can see the Cerbo GX Pi icon on the device list. When I click on the Cerbo GX Pi icon, I can click on the VRM button (shown in the photo below) and then get connected to the VRM web page.
When I first connected to the VRM web page using the Cerbo GX pi, I registered and installed the Cerbo GX as instructed per the menus.
However, I can see no data being uploaded from the Smart Shunt via the Cerbo GX to the VRM web page, where, I think, data is supposed to be shown.
Here is a sample photo of what I see on the VRM web page (my Pi is named"rfsraspberrypi1" as shown below):
I am connecting my laptop to the VRM web page using the same WiFi address that I have set up on the Pi.
I know there are many steps I went through to get to this point that I have omitted in order to not clog up this initial post. I hope that your further questions will flush out more helpful information, including me posting more photos if that would help.
I have started this separate thread so as to avoid mixing up different problems.
I am very grateful for all the help I have received so far concerning my problems.
Thank you!
Please screencap the "device list" page.
Are the following fully updated to the latest software/firmware:
VenusOS to 3.12
VictronConnect app
Smartshunt
EDIT: Confirm the shunt is connected to a battery... :)
Your raspberry pi hasn't sent data to the VRM for the last 10 days. That's probably why you're not seeing any smart shunt connected.
Are you using a WiFi connection or a hard-wired ethernet connection for your internet on the raspberry pi? Obviously it connected to the VRM at some point, but it doesn't seem like you've have any internet connection on the pi for the last 10 days.
When I click on the VRM "Remote Console" button below:
The following error screen appears:
My understanding is that, after I click Remote Console, I should see something like the following screen (but I do not, I get the Remote Console error message shown above):
I remain stumped!
When I click on the "Remote Console" button below:
I remain stumped!
You'll only be able to access the Remote Console from the VRM if your pi is connected to the VRM over the internet. It's not opening up your local Remote Console.
Until you get the pi back on the Internet, you won't be able to use the VRM for anything.
I am using WiFi.
Agreed.
I went to my network settings on my laptop, but the Pi, loaded with the Venus software, does not show up as a WiFi address on my laptop.
So, I removed the Venus SD card and installed the Raspberry Pi 4 SD card back into the Pi. Now, with the Raspberry Pi software, I can see the Pi connected to the same WiFi network that is connected to my laptop. In other words, the laptop and Pi are using the same WiFi connection.
However, even with the Raspberry pi SD card loaded on the Pi, my laptop does not show the Pi as an available WiFi connection.
My WiFi network connection is named CXNK00886F2D and shows up on both my laptop and the Pi.
So, I removed the Venus SD card from the Pi.
Now, with the Raspberry Pi SD card running the Pi, below is a photo of what I see on the external monitor connected to the Pi:
As you can see, running the Raspberry Pi software, the Pi is connected to the WiFi connection named CXNK00886F2D, and I can serf the web using the Pi.
But still, the VRM is not connecting to the Pi via internet.
The different SD cards running the different operating systems contain all the configuration parameters for the device. You cannot configure the wifi while running the Raspberry Pi OS and have it stay connected when you switch to the Venus OS. You have to configure the Wifi in the Venus OS.
The easiest way to do this is to take your raspberry pi (with the Venus OS SD card) and plug it directly in to your router. That will give you access to venus.local and then you can configure the wifi from there in the Venus OS. Once you have a successful Wifi connection, you can unplug the raspberry pi from the router and plug your smart shunt back in.
Once you can access from venus.local, go to Settings -> Wifi -> Wifi Networks to connect to your wireless network.
Thanks Adam!
Here is a photo of the router mounted low on the wall in a room on the other side of the house.
On the underside of the box on the left, are some ethernet ports, as shown below. I had to use a mirror to get a view of the underside so the photo is a reverse image with reverse text.
The two grey ports on the left say"phone". The four yellow ports say "ethernet".
Are you saying that I need to plug one end of an ethernet cord into one of the yellow ports and the other end into the Pi?
If so, does it make a difference which yellow port the ethernet cable is plugged into?
Thanks Adam!
Correct. Just plug one ethernet cable into any yellow port and the other end into the raspberry pi. That should give you your internet connection.
Read the accepted Answer
Darn!
Later on in the article, the "accepted answer" was found not to be correct. I read the article three times and am unable to understand if a solution was ever had, apart from Python programming via Terminal, which i do not understand.
Thanks for the article!
