upontheridge
I have a 2022 Keystone Carbon 338 with the SolarFlex 200i setup. That setup comes with a 200 watt solar panel on the roof and a Victron MPPT 75/15 Solar Controller. The RV also has a WFCO 9875 converter/charger that says it has a 13.6 Output. I want to add 2 Lithium 100amp-hour batteries and a 1000-watt inverter. My questions are as follows:
1. Do I need to replace the WFCO 9875 converter/charger or can I let it charge the LI batteries to 13.6 and then let the Victron Solar Controller handle topping off the LI batteries.
2. If I need to something other than the WFCO 9875 what would you recommend replacing it with? I have read the WFCO auto-detect is a less-than-optimal device.
3. Can I keep the WFCO device and purchase an inverter with ATS and charging capabilities? Can the LI batteries deal with charging come from the WFCO device, the inverter charger, and the solar charger?
4. For the LI batteries. I am considering Redodo batteries. My battery compartment is not in an insulated area. I don't plan to camp in sub 32 weather on a regular basis but may have a night or two that temps may drop below 32 degrees. I don't have a problem charging running a generator for power if temps drop below 32 degrees so I don't think i need a battery with built in heat but wondering if I need a battery with the 32 degree charging cut off as batteries would be connected to solar charging.
5. Trailer when stored may result in batteries experiencing below 32 degrees temps. Do I need to remove the LI batteries or will they be okay as long as they are partially charged and not being charged.
Thanks for your help.
