Aikalowych
Can you elaborate on not purchasing renogy batteries as I just purchased one less than 24 hours agoNo, it will charge the new lithium with the lead profile. There is no equilization. The charge profile is 14.4 charge, 13.6 float and 13.2 maintaining. Most of the time the converter will be at 13.6 volts powering the RV circuits, this should be no problem for the battery.
If you select a battery that has Bluetooth communication so you can, via the app, monitor cell and battery status, this will give confidence that all is well with the battery. Do not purchace a Renogy battery, they are causing many problems
If the battery will be exposed to freezing conditions ensure it has low temperature protection to prevent charging at low temperatures, or consider 'self heating batteries ' .
It is their newest model pro series smart lithium iron phosphate that does have Bluetooth and self heating function. So hopefully any issues you bring may have fixed with this latest model.
