The current set up is a 48v Lithium battery feeding a 48v -> 12v converter that is connected 24/7/365 to a 12v deep cycle battery that feeds the entire 12v system(s) in my RV. The 12v battery is inline to act as a load buffer for when I use the high draw 12v systems IE the Hyd motor for the leveling system, the slide motors. The big draw is from the Hyd at 45+ amps. The best converter I could afford for the build was the 30amp Victron. Thus the need for that buffer battery to suck up the load.... and FYI, it is very short time usage. The 48/12 converter is currently feeding 13.2 volts to the LA battery.
To the query. I propose to to replace the LA batter with a 280ah/100amp 12v Lithium battery that I am building. Once I have the Lithium battery built, balanced and fully charges, what voltage would be best to set the 48/12 converter to? There is a BMS in the battery, but once in service I propose to just feed it the voltage I set the converter to.
Thoughts?
(Why? Becasue the old LA battery is not in great shape as it was abused in a former life. The 280ah replacement will allow me to disco the 48v system from the 12 for an extended time to facilitate other work. )
Thoughts?
