Hi Jo,Whenever you have your 48V inverter running, or shore power just use one of these :
The last 12V 100Ah LiFePO4 battery I bought was just over $170 with tax, delivered. Add the charger and you’re still under $200 for everything.
Also, there are many MPPT’s that can charge both 12 and 48V nominal LFP.
Your choice but dismissing a 12 and 48V system often costs more. Remember that step down converters draw power when idle also but a simple switch can solve that issue with minimal additional complexity.
A little charger would be fine for a couple of lights, but 30w is a little frugal even for me.
The point of a bigger charger is to be able to get off shore power or the generator faster.
I'm not dismissing a 12/48v system, as mentioned, it's what I have. I'm merely pointing to some of the considerations getting there:
- check your house 120/12v converter for LFP compatibility,14.4 volts (etrailer has info) It might be cheaper/easier to just switch to a 12v LFP
- If you are combining, check your loads. Use an clamp meter to check YOUR draw from jacks etc. to find how big/how may converters you might need (I know Victron says theirs can run parallel) My setup uses much less than others report.
- check any appliances or equipment for minimum voltage requirements. For example my fridge wants 12.2 or alarms even tho actual cutoff is 10.something volts. The converter I bought puts out a steady 12.1 and the fridge puts out a steady beep beep beep. Probably better in my case to have purchased THIS 13.8v. Or the Victron Orion 48/12 30a with I think 10-15v adjustable, and 40a surge
