Hi,
I have a small camper with OEM WFCO 8735P (non lithium) and inverter, transfer switch (GoPower T-30).
I currently have the AC wires of the WFCO converter/charger wired into the transfer switch so it only charges the battery when on shore power.
I want to upgrade to a stand alone Victron charger (IP 22) and connect the DC side of the Victron to a busbar to charge the batteries.
If I disconnect the AC wires of the WFCO charger/converter at the transfer switch and wire in the victron charger, am I correct to believe this will also disconnect the 12V side of the WFCO so the 12V devices will no longer work? i.e the converter charger not only charges the battery , but powers the 12V devices.
Any other ideas how to do this.
Thank you
Thank you
