These 18V regulators are 27W each, so 14 in parallel for 378W at $5.44?
Looks like you got 27W = 18V x 1.5A
How well does the output current balance if you try to parallel them? Maybe need a resistor on each to help balance?
Max junction temperature 125C, let's shoot for 110C to maintain some margin.
Assume 40C ambient? (I usually try to make things work at 85C.)
110C - 40C = 70C temperature rise
Theta J-C = 5 degrees C/watt
Theta J-A = 60 degrees C/watt (if no heatsink)
Power dissipation is nominally (24V - 18V) x 1.5A, 9W each. Let's use (28V - 18V) x 1.5A = 15W
With no heatsink, 70C/60C = 1.17 so only 1.17W not 15W without overheating, need 12.8 times as many. 12.8 x 14 = 179 regulators needed.
With an infinite heatsink kept at 40C, 70C/5C = 14W. 15W/14W = 1.07; 1.07 x 14 = 15
So it could be done with 15 regulators in parallel if current perfectly balanced between them, heatsink limited to 40C, while keeping junction no higher than 110C for good life. Large heatsink and a fan could do it, or water cooled.
Don't even try to boost output current with MOSFETs. Their Safe Operating Area for DC doesn't come anywhere near the SOA in the datasheet (local thermal runaway of transistors in the die.) Bipolar transistor as source-follower after a regulator could work better.
I found a transistor which looks like it could work, but I don't think you'll like the price:
Order today, ships today. JANTXV2N5686 – Bipolar (BJT) Transistor NPN 80 V 50 A - 300 W Through Hole TO-3 from Microchip Technology. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
Here's a more affordable one but only rated 15A. Could parallel two with an "emitter degeneration resistor" to balance them:
Order today, ships today. 2SC6145 – Bipolar (BJT) Transistor NPN 230 V 15 A 60MHz 160 W Through Hole TO-3P from Sanken. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
Five of these resistors in parallel for 5W, 0.164 ohms:
Order today, ships today. RSF100JB-73-0R82 – 820 mOhms ±5% 1W Through Hole Resistor Axial Flame Proof, Safety Metal Oxide Film from YAGEO. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
One 18V regulator, two 15A NPN transistors, two resistors of about 0.17 ohms 5W could work.
The transistors have 0.78W theta J-C, 56 degree rise when 17A split as 8.5A each.
These transistors rated 150C, operate at 125C junction or below for margin, OK for heatsink up to 68C.
Looks like about $10 worth of parts plus shipping (which would be about $7 in the US for priority mail, might go first class overseas.)
Heatsink and fan not included, left as an exercise for the reader.
