Nimrod5
I have an off grid 40 that I put my camper on and built a barn. I live there summers. Cabin as soon as I can afford it. I currently use a 3000 watt generator to run a 1/2 hp well pump, a 5000 BTU AC, a table saw, and assorted tools. I was gifted six 265 watt solar panels and a Midnite Solar Kid charge controller. I will buy a battery bank and inverter and set up a system this summer.
I am fascinated by the Schneider SW 4048. I have found only this inverter (and the bigger SX) that can take the output from my 3000 watt, 120 volt, generator and add it to the output from the batteries to produce a higher wattage than the inverter alone and do it in either 120 volt or 240 volt mode. Does anyone have any real world knowledge of the total watts available when the 3000 watt genny and the batteries are feeding the inverter. Is the output in 120 volt the 3000 watts from the genny plus the 1900 watts from the batteries for a total of 4900 watts? For a 240 volt load is the total 3800 watts from the batteries plus 3000 watts from the genny equals 6800 watts?
The SW 4048 probably does not have enough output by itself to start the table saw or the well pump. The 3000 watt genny alone just barely does. I would have to run the genny plus the inverter to start these loads. I have a small 240 volt stick welder that runs just fine on grid power with a 20 amp breaker. That's 4800 watts. Could the SW 4048 plus the 3000 watt genny run the welder? I don't know what the start up draw is for a stick welder.
