Will's video on the EG4 6000xp says with the split phase only 3000 watts are available as 120 volt. Signature Solar says all 6000 w can be available as 240v.
I would like the EG4 to feed the 240 v directly to my 200 amp main in the house. Is this correct and would the same be true if 2 EG4s were connected in parallel.
Does the EG4 have connections for 2 wires to pickup the 240v (120 for each leg) plus a third connection for the 120v out put Thanks for your help. Still lots to learn.
