Another question, hopefully not a dumb one. Would someone be able to clarify what the proper method is to match cells when creating packs? In this case 4 cells for 12V packs...
A year ago I purchased two separate sets of 8 280AH Eve cells from 18650batterystore about 6 months apart (so 16 cells total). Each order was supposed to be batched and matched (probably were, I don't know). Once I received each order of the 8 cells, I tested each cell to determine its AH capacity. I then "matched" the cells in groups of 4; based simply on AH capacity. In the end I had 4 12V packs, each with cells that most closely matched one another based on AH capacity from my testing.
I recently had a separate thread started asking about why these 4 packs discharge at different rates. And then today I had this epiphany that maybe when I matched the cells, I didn't do it correctly. Perhaps AH capacity isn't the factor that one should use when matching cells for a pack.
