I currently have a grid tied Enphase 4.6kw system and I'm planning on adding about 3-4kw. We have a reliable grid but would like some backup. AC coupling with hybrid inverter and battery seems like an expensive nightmare for the 0.01% of the time I would need it. Our POCO has no time of use.
The new array with be vertical on deck rails meaning easy access. I'd like to run Enphase micros as the additional cost is minimal and I have plenty of space in the combiner box.
In grid down situation I plan to use a Bluetti AC300 with PV input from a normally inactive branch of a Y-connector from the panel MC4 with the other, normally active, branch to the micro for the panels. When the grid goes down the micro's shut down. Bluetti will then plug into a manual transfer switch powering a critical load panel. I would then power that panel and input the PV wiring from the Y-connectors into the AC300 to charge. I also have a method to dual charge the Bluetti from our EV at about 1kw in this situation.
Any issues with this?
Also, as an aside, I plan to run the voltage step down unit sold by Bluetti (D300S) so that I have max 2.4kw solar input for longer during shaded/cloudy times. It will take a max 550VOC string and convert to the max 150VOC for each MC4 input of the Bluetti. Does that seem reasonable?
