Hello all, just wanting to get some opinions on what to do next or if I'm at a point now to call it a day adding to my system.
I have around 2.2kw of panels;
4 x 260w in series to a PowMr 60amp controller
4 x 215w in series then in parallel with another 4 x 75w ish (270w badly smashed panels) to another PowMr 60a controller
Breakers on panels to controllers
2.6kwh of batteries which is 4 x 55ah AGM in series for 48v was 8 x but got some are not happy batteries.
Breakers on controllers to batteries
No breaker currently on batteries to inverter, do I need one here ?
This all then connects to a GTIL 1000W inverter which has a limiter for zero export via CT clamp.
Everything in I have spent around £800 all DIY.
I am on a peak / off peak tariff
Peak 01:30am > 8:30pm 15.18p
Off peak 8:30pm > 01:30am 5.5p
I am shifting most of my loads like dishwasher and washing machine but the main bulk is chargers for batteries and the hottub which is set to bring the temp up to 42C off peak and it slowly drops during the day to 34C to reduce peak usage.
I am covering most of my peak costs with solar/batteries as you can see from the graphs, light blue is off peak, dark blue on peak.
So a good day looks like this;
Bad day looks like this;
So everything I have added up to now has been super cost effective but I don't know if I am at the point I will be throwing money at it and not really seeing any cost benefit.
I could possibly replace the 4 broken panels if I come across some cheap ones again to increase PV and I will likely sort my battery problem to double the capacity but spending £800 on some lifepo4 and replace the chargers etc I am going to spend more on that then the whole system cost up to now and isn't really going to save me much in the long run.
At the end of the day it started out as a bit of fun/hobby but worked out well so slowly added bits.
I really appreciate your opinions.
Cheers
Cheers
