Saad194
The client aims to power various loads using the solar PV system during both day and night.
The day is divided into three time periods:
Off-peak time: 8 AM to 5 PM
Peak time: 5 PM to 10 PM
Off-peak time: 10 PM to 8 AM
The load distribution throughout the day includes the following:
AC 1.5 ton (a) inverter Gree company: 1800 watts (1.1 KW on average per hour when running) run 24 hours.
Fridge: 350 watts run 24 hours.
2 fans: 100 watts each run 24 hours.
10 LED lights: 12 watts each (operating for 12 hours)
AC 1.5 (b) running from 5 PM to 6 AM run 13 hours.
AC 1.5 (c) running from 9 PM to 6 AM run 9 hours.
The system will be installed in Lahore, Pakistan.
Grid charges:
Off-peak time: 57 PKR per unit (KWh)
Peak time: 62 PKR per unit (KWh)
The proposed inverter is Nitrox 8 KW Hybrid, and the solar panels will be either Longi or Jinko 580 watts mono Perc. The quantity of solar panels will be determined through calculations.
Three types of batteries will be considered:
Lithium-ion (Narada brand, 48V 100Ah, efficiency 80%)
Gel type (Narada brand, 220Ah 12 volts, efficiency 70%)
Tall tabular (Exide brand, 220Ah 12 volts, efficiency 65%) require calculation how much solar PV , inverter, and battery bank
Grid charges:
