31ectr0nicb0b
My kids and I are building a barn since the pandemic and its at a stage where its ready for some power. I'll be getting a standing seam metal roof installed soon so I need to address the PV DC input and array size.
I am planning on doing a series-parallel connection for [4] 24V banks with 100Ah capacity each using the batteries listed below. This should equate to [4] 24V banks with 400Ah total.
This is what I have so far (everything comes bundled and mounted as seen in pic above):
- [8] Battle Born 12V 100Ah BBGC2H
- I am in the middle of charging all of them via the Victron charger below
- https://battlebornbatteries.com/product/12v-gc2-lifepo4-heated-battery-kit/
- Victron IP65 15A charger
- Midnite MNPVHV8-DLTL NEMA 4X-PSB Disconnecting Combiner
- The MNPV8HV-DLTL allows you to take 4 strings in and combine them into 2 strings out. Strings 1 and 2 go
to channel A out and Strings 3 and 4 go to channel B, allowing for two MPPT channels out to a transformerless
inverter. - https://www.midnitesolar.com/documents.php?productCat_ID=26&model=MNPV8HV-DLTL 4X&product_ID=573&act=
- https://www.midnitesolar.com/pdfs/10-065-1_REV_M_Combiner_Manual_10-16-19.pdf
- https://www.invertersupply.com/index.php?main_page=product_info&products_id=200189
- Midnite Rapid Shutdown Power Supply Board MNDISCOPSB
- [Placeholder] Midnite Birdhouse
- [2] Surge Protection Device MNSPD600
- Outback FlexPower one FXR
- FlexMax 80 Charge Controller
- Mate 3s System Display and Controller
- FlexNet DC Battery Monitor
- HUB Communications Manager
- [Placeholder] Lacking PV array
- [Placeholder] Lacking PVRSS PV Rapid Shutdown System
This is a link to a quick start guide of the entire system:
