Sback New Member Joined Jul 5, 2021 Messages 109 Sep 7, 2021 #1 I just hooked up a 60 amp 4s 12volt dally bms and when charging at 20 amps it reads -20, is this normal. Seems like it should say positive. Attachments Screenshot_20210907-210206_SMART BMS.jpg 166.5 KB · Views: 4
2 25DarkKnight New Member Joined Sep 8, 2021 Messages 1 Sep 8, 2021 #2 Yes this is fine, it showes discharge current so technically you're doing a negative discharge. It's a little weird but you'll get used to it
Sback New Member Joined Jul 5, 2021 Messages 109 Sep 8, 2021 #3 25DarkKnight said: Yes this is fine, it showes discharge current so technically you're doing a negative discharge. It's a little weird but you'll get used to it Click to expand... Ok. Thank you.
