TheGriz
More Power Scottie!!!
- Feb 17, 2020
- 128
Hello folks...first a little background. I was using the Chargery 8T BMS on a 4S EVE 280 AH LFP pack. I ran into one issue after another, until finally it just simply wouldn't turn on. BUT please I don't want this thread to be a about who has had success or issues with the Chargery. I am moving on and looking at an alternative.
I have been looking several other BMS, of course as the topic suggests, the Daly BMSs. Now I understand that Daly has the smart BMS where the parameters can be set for HVD and LVD. But looking at the "non smart" Daly, the voltage disconnects from what I'm reading in specs are outside safe parameters of LFP prismatic cell. As we know the low voltage limit is 2.5v for LFP, but the Daly LVD is 2.2V. Conversely, the LFP high voltage should not exceed 3.65V and the Daly is 3.7v. So with these Daly specs, I see the the LFP aluminum case prismatic cells being damaged being discharged/charged outside the LFP specs.
Having said that, I see the Daly BMSs being commonly used in many builds of LFP aluminum cased prismatic cells. Please help me understand...what am I missing?
What are everyone's' thoughts on a quality 12V 4S BMS that won't break the bank, and has low-temp protections. I'm hoping for 200-250amp and still have separate ports for charge and discharge.
Also, the mechanical 400A DC Contactors that came with the Chargery are ridiculous energy hogs and get stupid hot. What are other energy efficient alternatives.
Thanks for all anticipated responses,
Mike
Mike
