Good luck with the project JoshCliffeJones. I am on the edge of buying a new BMS just incase. CattleRustler on this thread: https://diysolarforum.com/threads/darfon-growatt-gbli5001-battery-pack-problem.42129/#post-574308
has led me to believe the GBLI5001 battery may also be faulty as a similar situation with his. He has found a little work around. I'm assuming no 3rd party BMS is ever going to communicate with Growatt's protocols, the bluetooth comms sounds good (that will be a BT chip that plugs in UART). The Daly BMS may even give more or allow more info than the current Growatt/Darfon BMS does. Good luck with that and with the CT clamp. I would love to see pics of your handiwork when you get it up an running; I will look forward to the dedicated thread![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
