Deadeyecustoms
I have a 13000w 28kwh 48v off grid solar system with two 6500w rich solar inverters in split phase & two 14kwh 48v big battery rhino power wall batteries. I have a native DC air conditioner that draws max 20amps & typical amp draw of 10amps. The manufacturer told me to connect the air conditioner direct to the battery busbars. My question is, since I'm drawing directly from the 48v busbars, and the only load off of this wire run is the efficient DC air conditioner that runs at 35w-10amps-20max. Do I size my wire for what the batteries put out or for the load my air conditioner will consume? If just the air conditioner load, will 6awg be sufficient & same question for putting a fuse or dc breaker in between the two. Does the breaker need to be 250amp which is the battery max or just 20amp which is the air conditioner max amp draw? My solar equipment has been installed inside an old Korean era Military Marine radio shelter. Which is designed to be a faraday cage itself with steel outer shell & mesh aluminum paneling inside. My run from the shelter to the air conditioner will be no more than 50'. My ac out loads will be in separate shielded conduit & exit in its own penetration. I was thinking of a DC breaker/disconnect right before the 48v wires penetrate the shelter. Any input would be greatly appreciated. Planning on hiring a solar professional once near completion to QC my work, but want to do most of the work myself to save cost.
