chrisski
Solar Boondocker
- Aug 14, 2020
- 5,226
I found both legs on my split phase for both my air conditioners were crossed. The diagram below shows what I mean:
So for the 16 years my house has been built, one 120 volt leg of the split phase leg from each air conditioner goes into Air Conditioning Circuit Breaker 1; the other leg of the split phase from each air conditioner leg goes into Air Conditioning Circuit Breaker 2.
I was testing circuits for my back up battery for my upcoming solar installation and I was puzzled when I tripped one circuit breaker, and both shut down. After a bit of trouble shooting I found the "wires were crossed." The four ton unit has a 40 amp circuit breaker and the five ton unit has a 50 amp circuit breaker, so you can see how I'm not happy about one leg of a 50 amp circuit going through a 40 amp breaker.
I will be getting someone out to fix this wiring. I hope it is as simple as changing where two wires terminate in a circuit breaker.
