Scenario:
I have a 48V 10 Amp DC power supply. Connected to it are two DC/DC converter electronics bench supplies. These are CC/CV units.
One of the PSUs is outputing 19.50V and is powering a laptop docking station setup. The other is outputting 12.50V and is running 2 USB hubs (charger ports etc.)
The problem is this. The 19.50V supply says it's outputting 0.5 Amps. So does the 12.50V one. However I know this is incorrect. The laptop docking station is drawing just over 1 Amp and about 22 Watts. What gives?
A current clamp and some selected unplugging reveals there are problems.
The + output of the 19.50V supply shows 1.1 Amps. The - output of the 19.50V supply shows -0.6 Amps. The clamp around both leads shows a positive 0.5 Amps. Where did the other half an amp go? Unplugging the HDMI cable from the docking station and the PSU jumps back up to 1.1 Amps.
Okay. So we have the DC ground on the HDMI cables and DP cables linking the DC current through the monitors and the PCs onto, ultimately the USB ground. However, the current does not show up on the 12.50V supply either. It is not returning via it. There are only 3 things connected to that 48V power supply. The two PSUs in question and ... the PE.
I have tested this by connecting a multimeter between the copper radiator pipe and the - lead for the 48V power supply and low and behold, 0.5 Amps flows from the radiator to the PSU.
What's even more disturbing is the 48V power supply is 10 meters away in the garage! That DC current, if my multi-meter was not helping it has to go all the way through the PE in the gaming PC, through the PE wiring to the consumer unit and from there out via the garage plug circuit PE to the inverter and then to the Earth on the DC power supply where it finally completes back to the earth referenced DC power brick where it started.
Throwing 1 or 2 Amps around this way is "curious" and I'm not overly concerned. Just annoyed I have no current limiting control and no valid current measurements from these PSUs. However. That 48V power supply is capable of 480W. The Victron Multiplus charger is capable of 16A and around 500W. It would be "losing" ground currents for those Amps which would concern me. Basically which ever device/path has the least resistance to return via is where the current will go. If that path happens to be something which will not take 16As of DC current, then it's going to get very, very hot and probably burn out.
In a similar vein my Victron multiplus seems to be the favoured DC return path for all the "admin" stuff like the raspberry PI, wifi access point and a few ESP32s for data monitoring/collecting. The MPPT controllers "load" is outputing about 200mA, but only random noise is returning and the rest favouring the RaspberryPI USB to the Victron and from there to the battery.
I don't think there is a solution to this, other than maybe introducing a few selected isolated DC/DC converters. However, as soon as you connect two devices together which share a ground, that isolation is broken.
Any thoughts? Anyone been down this rabbit hole?
Acronyms:
CC/CV constant current, constant voltage
PSU - Power supply unit
MPPT - Max power point tracking (solar charger)
PE - Protective earth (the third pin!)
ESP32 - Wifi/Bluetooth gizmo
HDMI/DP - Monitor cables
Acronyms:
