SolarBro
Solar Budgeteer
- Jun 27, 2020
- 91
Im getting closer to finishing my lv5048 install and i have another bonding/grounding question.
Some say that the DC negative bus bar from my MNPV6 combiner box should be bonded with the ground bus bar.
The reason for is a path for the DC positive to find a path to DC negative to trip the breaker in the MNPV6 box. However im not sure about this.
Some also suggest bonding the ground and negative terminal on my battery bank. I have tesla modules and i dont like that idea of sending possible voltage to it if there is a ground fault somewhere.
Have you or how have you handled bonding the ground and DC negative on MPP solar arrangements?
Or is the DC negative and positive "floating" from the MNPV6 combiner to my mpp LV5048?
(All metal boxes and PV panels are grounded together and combined in the MNPV6 ground bus bar currently btw. I do not have a DC neg to Ground bond however)
