Thanks. It says that it tries to keep the starting battery 0.2 volts below the house battery.
In boats, we just keep the starting battery(batteries) holy and sanctified. For offshore/great lakes often there are two starting batteries- one as backup due to the redundancy for life safety purposes. Then all systems/lights/vhf/radio are run on a separate house battery system. Because a dead starting system can be life threatening on big water.says that it tries to keep the starting battery 0.2 volts below the house battery.
Yes, you could use one but I would not. I’d rewire to sanctify the starting battery.Are there any DC to DC Chargers that will charge the starter battery once the house battery is charged while the alternator is off?
To do this i have in the past just used a VSR and wired it up backwards then as the house battery is charged via solar it switches on and charges the starter battery, IF that is they are the same chemistry ?
Although now i use DCC50s which does it all (solar controller and BtoB and reverse BtoB) the prev VSR worked fine though.
Probably fine with lithium for me: turn on the glow plugs, push the button to join both battery systems, engage the starter once the glow plugs are hot enough, let go of the button once the engine is started — there’s no “high” voltage going to either system for long enough, if at all.My ambulance has a jump button, it just manually engauges a solenoid, the same one the conversion builders used for the ambys split charge system, but in my case i have a seperate ambulance systems battery for this and it's the same chemistry as the starter battery, no good if your 2nd (house) battery is a lithium, which mine is hense the DCC50s (i have 3 battery systems, total overkill but it came with the amby)
