Huh? If paralleled, each panel sends and receives only its own generated current. (They've got diodes which prevent reversals on each internal "string" of wafers). The common and shared wire pair "+ " and "-", handles much higher current, but the individual panel leads will never see that. The fuse size for each panel, if fused individually, must be larger than 6.10A (and 10A is a good value). The fuse size for all panels combined in parallel, if installed in the "common" wire to the MPPT, must be greater than 6.10A * 5 (40A and 50A would both be good values for fuses installed on those leads, connecting to the SCC). If I'm confused, please explain with a picture.
