I just commissioned mine. Unbelievably simple compared to the 2012 SMA Sunny Boy SB4000US I just gave up on. The alarm/warning LED is on solid but I think this is because no battery is connected. There has to be some way to set the inverter time/date and change other things via the ZIGBEE interface. Anyone know about that?
Search youtube. There is a new guy testing solar with it running Air Conditioner batteryless mode with many panels.anyone using this one? i am planning put this one with 12 sunpower 230W panels and connect back to the grid.
I always thought the 300 seconds was part of the original UL 1741 standard and was not a specific inverter setting. I seem to recall in UL 1741SA that one of the reasons for frequency Watt modulation was so that if the grid went skightly off frequency all the rooftop solar would not drop off the grid at the same time. I may be thinking of the CA or HI rules, I don't remember the details.I don't know why designers wait so long to reconnect to the grid.
I understand, and don't know what the logic was for that long reconnect time. Maybe it was a hardware thing from years ago? I once had an old Xantrex inverter drop off because of high voltage of the grid. When I talked to an Engineer at SCE he told me they regularly adjusted the voltage at substations based on seasonal loads. They had been delayed in adjusting my particular substation back down. That gave me insight into how antquated our grid actually was if that had to be done manually.That isn't the drop off time, though - it is reconnect wait period. This unit drops out at a few readings below 180 VDC.
I also don't know if the new standard changed the reconnect time or the algorithm. Even if it is still fixed the more random the drop of time is for inverters on the grid then the exact time that individual inverters reconnect will more likely be staggered. All of this is me trying to understand whatever logic went into the stabdards.You don't want all installations dropping off or reconnecting at the same time though.
