I am designing a small LFP-based system for use while traveling in my Subaru. I have built a 640Wh 12V system to learn and now have questions.
I am a novice at solar systems. I have a decent understanding of AC & DC power. I understand batteries fairly well from years as a flashaholic. I am very comfortable working on AC systems, less experience with DC systems. Not an expert on either, but I mostly understand the boundaries of my knowledge. I get up to speed pretty quick.
I will lay out my thoughts, ask questions inline, and then summarize questions at the end. I apologize for the length, but want to be comprehensive.
Constraints and Context
My primary design constraints are interior space for components, and roof space for panels.
Cost matters, but is not the primary limiting factor.
I tend towards overkill, infusing margin to avoid problems. I am cognizant of failure modes and edge cases and try to avoid them, especially when they might hurt. I may need some help slowing my roll here.
The battery needs to fit into a single second row footwell 19” wide and 10.75” deep. Height can be up to 14". I’d prefer a shape that is squat rather than tippy to ensure stability. I have the other footwell earmarked for a water tank so it will not be available. The water tank will also approximately balance the weight of the battery with an equal-ish weight of water. I have the trunk earmarked for other things.
My roof rack is a platform with a 2” raised lip. Inside dimensions are 43” wide x 59” long. I’d prefer to keep any panels inside that, but would be willing to add 2-3" to each dimension and overhang the rack a bit.
Other parts (SCC, inverter/charger, DC-DC charger, 24V-12V stepdown) may live above the battery, or in other locations. Once I make the battery decision, I'll Tetris all of the other stuff.
Planned Loads
Inverter Sizing
Planned AC loads are almost 100% resistive and top out at 1000W. I'd think I could get by with a 1000W inverter, except for efficiency losses in the inverter. 1500W would give me some headroom and account for that.
I think I want an inverter/charger to allow for charging using shore power, and, ideally, passthrough power when plugged in.
The Victron inverter/chargers are HUGE. Looking at Xantrex and Samlex but haven't dug in that deeply yet.
Batteries, capacity, and system voltage
I was initially thinking I’d do a 12V system. However:
Most 100Ah batteries have a BMS with a max continuous discharge rate of 100A, and a 1500W inverter will need to draw 150A at 12V DC at max output. (I recognize that the inverter has a peak capacity, but I’m not concerned with designing for the peak draw.)
So I either need 2 100Ah batteries in parallel, or a larger battery with at least a 150A BMS. A two battery arrangement is attractive from a fault tolerance standpoint but may not be feasible from a space standpoint. If I have to choose between fault tolerance and capacity, I’ll pick capacity/discharge.
A 1000W inverter pulling full rated 100A discharge from that one battery also seems to run it pretty hard.
That BMS discharge constraint informs the space constraint, in that 2 “normal/drop-in size" 100Ah batteries (in parallel) will not fit in the footwell. Most 100Ah 12v batteries seem to be around 12-13” long x 6-7” wide.
The 12V batteries I have found with a 150-200A BMS are 200Ah+, and are also physically too big to fit in the footwell. Examples include the AmpereTime 200 Plus, at 20.5” long. Even if I could fit one, which I can't, I could not fit two, and one at 12V is only 2.5 kWh, and I’m seeking at least 4.2 kWh.
Standing a “normal” form factor battery on a small end puts one battery terminal close to the floor, so that’s out due to concerns about instability and damage to the terminal/cable. However, the BattleBorn BBGC2 or BB5024 would work as a pair side by side without that concern. Problem is that only gets me 2.5 kWh of capacity.
All of the foregoing pushes me to 24V batteries, since the max draw of a 1500W 24V inverter would only be 75A at 24V DC. I can wire the inverter with 4AWG. The Dometic and USB chargers will happily run on 24V, so that’s fine. If I end up with any significant 12V loads, I can get a 24V-12V converter.
So, 24V looks like the logical choice. However, if I’m leaving 12V behind, is there any compelling reason NOT to just jump to 48V? I’d need to add a 48V to 24V (or 12V) DC converter, but that’s not a huge deal, I don’t think. I will likely use this system inside the house when I’m not on the road, mostly as a power outage hedge, but do not plan to put this battery into a full house system. If I go that direction, I’ll probably get a stack of server rack batteries.
I know I'd need higher OCV panels if I went 48V.
I’d definitely appreciate thoughts on other battery manufacturers that might have form factors that’ll work in that footwell space. BigBattery has some interesting options but I have read enough to eliminate them.
I have found Electric Car Parts Company, who seem to have some really nice 12, 24 and 48V batteries that are all 5.12 kWh, and all 17” x 10.5”. They are expensive, but seem ideal for my use case, lacking only low temp charging protection.
Panels
I am having difficulty optimizing the roof space available. The roof rack is a platform style with a low (2”) circumferential lip. As I said above, the platform inside the lip measures 59” x 43”. Willing to add 2-3" to length and width if needed. I’d welcome suggestions for rigid panels that would make the most efficient use of that space.
I will need to consider portable panels to augment while in camp. I’m not in love with the non-rigid folding panels, as they seem unwieldy, but need to look into those more. I’m considering a suitcase style rigid panel, but they are hard to store. I like the CIGS flexible panels as a possibility.
I think I'll top out at 350W for rooftop panels and know that I will be severely under paneled vs my battery capacity. I don’t know to what degree that will be an actual problem and would welcome input. Since I’ll allow for shore charging, that will help to some extent, but don’t want to rely upon that.
Alternator Charging
My Subaru has a “smart” alternator that stops charging under various circumstances. If I were not under paneled, I’d probably skip any DC-DC charging, but it seems like this might be worth doing given that I’ll probably max out at 300W-350W on the roof. Having this ability might be very helpful.
I know I’d need a 12V->24V DC-DC charger, like the Victron Orion 12/24-10. I can’t determine whether the negative connections for the 12V input and the 24V output are on a common bus, but suspect they are.
Are there any issues using the chassis of the car as a negative ground path for a 24V house system when the car voltage will remain 12V? If my assumption above of a common bus is true, then I imagine the answer is no, but want to confirm.
Summary of Major Components
Question summary:
Planned Loads
- Critical - 864W:
- Dometic CFX3 75DZ fridge
- 12/24V DC
- Estimating a pessimistic draw of 36W/hr for 864 Wh/day
- True worst case load around 60W/hr for 1440 Wh/day
- I’m planning to put a logging meter on this load so that I can get a longitudinal sense of actual consumption, but that’s not helping me right now.
- Important - 1240W:
- 4 USB QC 20W ports to charge various devices - phones, iPads, lights
- Estimate 5 devices getting a full charge from empty in 3 hours once/day.
- Likely to be less, probably 2-3 full charges/day.
- Estimating 300 Wh/day for all 5 charges
- 2 USB C PD 100W ports for laptops
- Estimate full charge from empty in 3 hours once/day per laptop
- Estimating 600 Wh/day, though it’ll probably often be less than that
- 1000W AC hairdryer
- Estimate 170 Wh/day at 10 min/day
- I have been gently advised by my travel partner that this is non-negotiable.
- 1000W AC electric kettle
- This could be a kettle on a propane stove.
- Optional/Occasional:
- DC Fans - USB-charged/battery powered or direct DC powered
- USB-charged LED lights
- Viair compressor (as needed)
Inverter Sizing
Panels
Alternator Charging
- 24V 5.1 kWh Battery
- 1500W 24V inverter/charger
- Panels
- SCC
- DC-DC charger
Question summary:
- Am I correct that a 1000W inverter is not sufficient, and I should go with a 1500W?
- Is it inadvisable to run a 1000W inverter hard up against the 100A continuous discharge rating of a 12V 100Ah battery?
- If I’m being pushed to 24V battery systems due to inverter draw, is there a compelling reason to just go 48V?
- Are Electric Car Parts Company batteries of good quality?
- Any other battery options I should look at?
- Any ideas for other batteries of 5.1 kWh that will fit into a 19” x 10.75” space?
- Any recommendations for high quality 1500W 24V inverter/chargers, with priority and premium for small dimensional size.
- Any recommendations for the maximum wattage solar panels possible with an OCV of > 28V DC, taking up a 59” x 43” area?
- How much of a problem will my under paneling be, practically speaking?
- Are there any issues using the chassis of the car as a ground path for a 24V house battery system when the car voltage will remain 12V?
- What should I have asked that I did not?
