Hello, I have portable obstruction lighting system, controller with integrated IC Max1648. It use 2unit 12v 7ah lead acid battery. After 2month replacing to new battery, the device trigger lowbattery after using it 2hour, the indicator will blink and shutdown itself after few minutes. Normally it can operate 6 to 8hours. I checked the battery voltage shows 10.8v after using it 2hours from 12.4V.
Then i replaced with new battery it happened the same. What cause or which component trigger the lowbattery. I have 4 unit, all same problem..
