I had a solar pool pump that unfortunately stopped working. Until I get a new one, I want to connect my conventional pump using the power generated from the four 350 Watt panels that were installed for the solar pump. I can use this energy through my LV2424 inverter, combined with grid power. The problem is that if grid energy goes down, the pump will suck the energy out of the battery in no time. To avoid that and still be able to use the energy provided by these panels, I need to turn the pump off when grid goes down.
Question: is there a device to monitor grid power and turn off the pump in case the grid goes down?
