I have a Solark 15kw Inverter, powered by about 6Kw of panels, and backed up by 25.6Kw of Eg4-Lifepo4 Batteries.
I used about 48kw per day of grid power in the fall to the spring and about 102 kw in the summer ... I live in Phoenix, AZ.
Since I commissioned my system, I have been averaging about 9 or 10kw per day of grid power. This summer of course will be the big test.
My house is almost fully electric. In fact the only thing powered by propane are two tankless hot water heaters. I have lots of big loads ... dryer, oven/stove, well pump, booster pump, swimming pool, hot tub, and 2 three ton HVAC units, and mini-split in my garage (which I rarely use). I have installed Micro Air easy starts on both HVAC and it does help by lowering the start up amp draw.
My hot tub only kicks on a couple of times per day for about 10 minutes to maintain the temp, so the next big drain (outside of the HVAC units) is the pool pump which needs to run about 8 hours per day. I have a Pentair variable speed pump and I have found a sweet spot of running it at about 3,000 RPM and this only pulls about 1380 watts, but still gets the pool cleaned.
My goal now, is to find low cost ways to add to my system in such a way as to use even less grid energy. One thought I have had is to go solar with my pool pump.
I found this Growatt 2.2 inverter specifically made for pumps. Their literature claims it can be used for pool pumps. I can't seem to get Growatt's US offices on the phone, despite repeated attempts.
So, does anyone have experience with this product, specifically using it for a pool pump? I guess my biggest concern is that the Pentair pool pump is controlled through a control panel and I just want to ensure that the Growatt product will properly interface and not mess up the system. It claims it can pull power from the grid and solar seamlessly.
Any help, advice, loose ramblings, ruminations, or advice found in consulting the tea leaves will all be appreciated!
I am new to the solar world, and now addicted to trying to minimize my grid usage!
Growatt 2.2kW 3HP Solar Pump Inverter l Water Pump Inverter | Grid-Assisted | SPI 2200TL2-HV
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LL
signaturesolar.com
