So I'm trying to find a solution/inverter to power this pool pump with PV panels and I'm looking at this:
Now, I'm having issues finding the specs of the pump, it's a 3hp pump but it says max power input is 3200W, does that mean this inverter wouldn't work?
I'm assuming grid-assisted doesn't mean 2.2kw from solar + whatever else is needed from the grid? I'm assuming it just switches between grid and PV?
Trying to find any pump inverter that's > 2.2kw is a PITA
here is the spec sheet for the pump, doesn't say much on power consumption:
Thanks
Growatt 2.2kW 3HP Solar Pump Inverter l Water Pump Inverter | Grid-Assisted | SPI 2200TL2-HV
(non-affiliate link to the inverter: https://signaturesolar.com/growatt-2-2kw-3hp-l-spi-22000tl2-hv/)Now, I'm having issues finding the specs of the pump, it's a 3hp pump but it says max power input is 3200W, does that mean this inverter wouldn't work?
Thanks
